Post by lakenheath24 on Jan 10, 2023 15:18:29 GMT -5
Just putting things together and my distributor is shot, shaft is loose as A goose and was wondering if the Rock auto pieces are ok or if there is an aftermarket version peeps are using?
This is a mildish build for a street car.
Post by Stinger on Jan 10, 2023 16:30:26 GMT -5
There aren't any aftermarket ones I'd suggest. The reman stuff can be hit or miss but they "hit" more often than not. Clearances are the main thing to be concerned with (as well as making sure to run the original gear that matches your engine so you don't create a gear mesh issue).
Post by lakenheath24 on Jan 11, 2023 9:29:34 GMT -5
Thanks, I appreciate the answer!
