Post by sponge003 on Apr 28, 2023 13:56:51 GMT -5
Having an issue with building fuel pressure using the Stinger fuel raile and FPR adapter. I am wondering if I have the connections wrong? Car was rumming prior to removing fuel rail, verified return and feed lines From tank goes to a side port of FPR adapter out of regulator to the fuel rail comes from bottom of FPR adapter Return comes from end of fuel rail ? Thanks
Post by sponge003 on Apr 28, 2023 14:03:23 GMT -5
Just swapped feed to fuel rail to a side fitting and tank feed to the bottom and still stuck at 20psi doesnt change not matter what I do to the set screw.
Post by sponge003 on Apr 28, 2023 14:07:37 GMT -5
The instruction picture only shows the side fittings and mine are not offset like the picture?
Also doesnt show what the fitting in the middle underneath is for?
Or I am an idiot and its right in front of me......
Post by sponge003 on Apr 28, 2023 15:07:51 GMT -5
Never Mind I am an idiot
Used a phone a friend and didnt realize full pressure goes to the rail first.....still learning FI basics
Post by Stinger on Apr 28, 2023 22:27:04 GMT -5
Yes, FPR can be viewed like a controlled leak. The more it "leaks" the less pressure builds up behind it.
