Post by rocco on Jul 18, 2023 10:51:10 GMT -5
the dot on the adjustable cam gear in stock location to initally to set up the cam was 2 teeth off when compared to the stock ford gear when put side by side and had a hard time starting car until I took it all off and made comparison and made new mark 2 teeth over. Car then started ok. Someone in the factory in charge of this should be made aware if others are like this. The adjustment was put in center so that was not the fault.
Post by Stinger on Jul 18, 2023 11:20:21 GMT -5
These are hand-marked, not part of the production process. They are marked by laying them over a stock cam gear and aligning the keyway. We'll look into what may have happened to that one. Thanks for the feedback.
