black
Post by black on Jun 10, 2010 12:25:16 GMT -5
The part with the hose coming out of the left side up to the intake manifold, attached to the block between the distributor and oil filter??
Post by merc460 on Jun 10, 2010 12:38:03 GMT -5
Crank case breather
black
Post by black on Jun 10, 2010 12:50:37 GMT -5
does it just pop straight off or is it threaded on there some how?
Post by merc460 on Jun 10, 2010 13:50:23 GMT -5
slight press fit no threads should just twist out. Unless it's siezed?
Post by denz on Jun 10, 2010 18:13:57 GMT -5
i call it a oil seperator. and yes it is a press fit i belive it has a o ring.
