hy40
Jun 13, 2010 8:39:53 GMT -5
Post by cjdavid on Jun 13, 2010 8:39:53 GMT -5
Anybody running an hy40? If so anything I need to know about them?
hy40
Jun 13, 2010 13:55:50 GMT -5
Post by Stinger on Jun 13, 2010 13:55:50 GMT -5
You mean hx40?
hy40
Jun 14, 2010 6:14:44 GMT -5
Post by cjdavid on Jun 14, 2010 6:14:44 GMT -5
I thought he said hy40 but you would know more than I on these turbo makes and numbers. So I will go with your knowledge.
Not gonna lie, I know about boosting but much of my past,(as referenced in my sig.) is N/A big cube engines. The old no replacement for displacement mindset.
hy40
Jun 14, 2010 14:38:24 GMT -5
Post by Stinger on Jun 14, 2010 14:38:24 GMT -5
An HX40 supports nearly 700hp. I wouldn't run it on anything but an "all out" 2.3. Matt's got on on the Bolt-On car but it wouldn't have worked without all the airflow mods.
hy40
Jun 14, 2010 18:47:54 GMT -5
Post by cjdavid on Jun 14, 2010 18:47:54 GMT -5
Ok so I have read the proven combos. Here is what I am doing to this car. It is going to be a driven car, but I want be able to to turn it up and have some fun at the track. The engine is a rebuild with about 40k on it. Don't know much about the rebuild but the guy is a jet mechanic and did some research. The head is ported, the intake gutted and the upper knife edged. Ranger roller cam, Stinger header, 3 inch exhaust, front mount i/c. Waste gate,turbo controller. What size turbo would you suggest? I'd love to see 300 some hp if this is possible
hy40
Jun 14, 2010 22:47:24 GMT -5
Post by Stinger on Jun 14, 2010 22:47:24 GMT -5
Well, the FAQ outlines some turbos for different hp ranges. To see over 300hp, you'll need to be willing and able to tune the ecu with a chip (or replace it with an aftermarket unit) so you can run larger fuel injectors and a better. The stock T3 is limited to about 300hp as well so above that, you'll be looking at a small hybrid or a holset hy35 or hx35. The last two options would be best served by a higher rpm cam since the turbo will spool at a higher rpm so you'll want to be able to rev to a higher max rpm.
