Post by krausauto on Apr 8, 2024 0:51:03 GMT -5
Ok I have the timing det at 20 degrees btc, like the instructions say to do. I went through switching the table and all, but according to the program, it's running like 17.5 btc. Should I adjust the distributer more so the program is reading 20 btc?
Post by Stinger on Apr 8, 2024 13:39:55 GMT -5
It should only read 20 deg when you have the software set to "Fixed Advance" and 20 deg. Once you change the software back to "Use Table", it will then not read 20 deg, it will do whatever the timing advance table or the idle advance table tells it to do. So once you do the fixed advance 20 deg, adjust it to read 20 deg with a timing light, and change it to use table steps, you're done adjusting the distributor.
Post by krausauto on Apr 9, 2024 23:14:40 GMT -5
It should only read 20 deg when you have the software set to "Fixed Advance" and 20 deg. Once you change the software back to "Use Table", it will then not read 20 deg, it will do whatever the timing advance table or the idle advance table tells it to do. So once you do the fixed advance 20 deg, adjust it to read 20 deg with a timing light, and change it to use table steps, you're done adjusting the distributor. That's what I thought. Thanks!
