Post by rchalmers3 on Jun 4, 2024 12:30:48 GMT -5
I'm offering a Ford 351W ECM with wire harness and wide band sensor (used) This is a complete “Plug & play” Stinger Performance “PiMPxs” engine management system off my 1988 Ford 351W engine. The ECM fits in the OEM computer location and has an internal MAP sensor. It is currently set up for batch firing the fuel injectors. If you have sequential fired injectors, a quick change of the internal jumpers in the ECM is all that is required. Wide band sensor is AES. Includes wire harness incorporates the wide band harness and has all emissions related wiring removed. This system works as designed and has only a few hours of operational time. Installation and operational instructions are included.
Reason for selling: I bought a basket case Bronco and after getting the engine running, I discovered the engine had low compression on 2 cylinders. I have decided to swap the 351 for a Coyote engine and am selling off all the good bits from the engine removal.
Images available on request. Please email me at: advenmotor@yahoo.com Location: Irmo, SC 29063
Asking $550 for everything, including shipping. A tuner studio license is required for performing tuning management. For more info go to Stinger-Performance.com
