Post by mattstang on Jun 30, 2024 21:14:58 GMT -5
I just purchased a PimpXS and dual Spartan lites for my Mustang and I'm trying to figure out the best place to mount the controllers. I have shorties and an H pipe and I'm planning on using the original o2 connectors to so I can plug them in the factory location. Speaking of that I know from past experience that the wires on o2 sensors don't solder well so I was thinking of trying to find replacement terminals and eliminate an additional connection, I don't really want to try routing them into the cab unless there is good reason, any thoughts on this? Anybody have any suggestions on mounting?
Post by Stinger on Jul 1, 2024 0:27:44 GMT -5
They are waterproof, just leave them under the car. Tie them up to the framerail or trans or anything other than the exhaust itself.
Post by mattstang on Jul 2, 2024 20:31:28 GMT -5
Thanks. They looked waterproof but I wanted to be sure mounting them that low would be acceptable.
Post by Stinger on Jul 3, 2024 13:17:23 GMT -5
It's likely "better" the higher you can mount them (like on the side or top of the trans) simply because they would be out of the direct water spray from the tires, and water will run away from them. rather than running down the cables towards them.
