Post by Corin Neal on Jul 1, 2024 14:36:15 GMT -5
Hey, what’s going on everybody hope you all are doing well. Just wanted to see what I needed to do to get the TPS signal to work. I have checked the signal wires and change the sensor and I still have nothing when I’m trying to calibrate the sensor.
Post by Stinger on Jul 2, 2024 2:39:52 GMT -5
You need to measure what you're getting at the connector/wires. You should have a 5v wire, a ground wire, and a variable voltage signal that changes with throttle position (about 1-4.5v). If you're not able to calibrate, you should find that you're not getting proper readings at the connector.
