4banger
BANNED
Post by 4banger on Feb 26, 2010 2:36:47 GMT -5
ok so i fixed my problem i think. some how my map sensor harnes came unpluged so i pluged it back in i also noticed a wire was melted from my vam its mostly white with a black stripe, so i fixed that, but i unpluged my vam and i took the little plug and wire out of the plugin and tried to put the new wire in so i did that, put it back together and went to start it. well it started up but it would not rev over 3k so i left it running and i went to my vam well i pulled the wire out of the vam and the car idled up so i rev4ed it and it would rev over 3k. so i dont know if thats is my problem or what??? i am also in the proses of traceing the signal return line to see if there is any crack's or if it is melted but so far nothing, i took it to a shop and they did a test and every thing is good compresion is good no bad rings, headgasket ect ect. the guy told me its definatly a fuel problem, he said maby a tps sensor. which he ran the codes and i want to say that is one of the codes, i also bought a ect sensor becuase i have noticed my motor temp is not moving. but do you got any other ideas??? o i also bought a new set of plug wires and plugs. these are the codes i got 22, 51, 54, 63, 66, 81, 82, 85, 88, i do know the one code is because who ever did the swap they used a computer for a auto and not a manuel, wich i was told that is ok.
Post by Stinger on Feb 26, 2010 4:00:51 GMT -5
Remember when I said to post all your info into one thread and quit posting a new thread every time you had an update? It still applies. Copy and paste this info into your 6 page thread here: stinger-performance.proboards.com/index.cgi?board=tech&action=display&thread=717&page=6You may also want to mention whether it is still smoking (and what color it is) since you always said it smoked before. If it's a fuel problem i assume you had them check the fuel pressure... This thread is now locked...copy it as stated above so people know what you've previously done and can help diagnose...
