dizzle
Post by dizzle on Jul 19, 2010 19:09:05 GMT -5
I am about 45 min. North East of Houston TX. In a little town called Crosby.
Post by Stinger on Jul 19, 2010 22:13:56 GMT -5
Hmm...don't know of anyone that can help you around there.
dizzle
Post by dizzle on Jul 19, 2010 23:08:12 GMT -5
i was able to get it installed i think. Thank you for the help. Here are some pics of what i am seeing on my end. the one that bothers me is the compatibility mode. Where is windows 7
Post by Stinger on Jul 19, 2010 23:28:04 GMT -5
You shouldn't need to run compatibility mode, that driver works with Windows 7 without issues (as long as your com ports are matched up as described earlier).
With that said, compatibility mode converts your operating system (Win7) to the older system of your choice (XP, Vista, etc.), that's why it doesn't list Win7...you are converting Win7 to XP or Vista or Win95 or whatever. You can't convert Win7 to Win7.
dizzle
Post by dizzle on Jul 20, 2010 16:42:54 GMT -5
I learn somthing new every day. I cant thank you enough for your help. I think i finaly might be catching on . I am going to try it again when i get off work this evening. check that out! boosting 10 psi! heck seemed like yesterday i was a newbie.
dizzle
Post by dizzle on Jul 20, 2010 21:05:44 GMT -5
i tryed changing the port but it is giving me the same error message. code 28. keeps telling me the driver is not installed. every time i try to rerun prolific driver (run as Administrator) it trys to uninstall.
Post by Stinger on Jul 20, 2010 22:19:01 GMT -5
The driver is installed, you don't need to run the prolific file again. Where did you try changing the port?
How about you tell me what port the driver is installed on in the control panel > device manager and we work from there.
dizzle
Post by dizzle on Jul 21, 2010 17:38:04 GMT -5
When i am in device manager, Where i should see : PORTS(COM & LP) I see an icon that says USB 2.0ser. I know that that is the Mega squirt because when i unplug it it goes away........When i click on that icon (where i should see tabs for, GENERAL, PORT SETTINGS, DRIVER, DETAILS, RESOURCES) I only see three tabs (GENERAL, DETAILS, and DRIVERS). I guess what i am trying to say is that if those tabs are not there, how do i change the port? I went to my fire wall and added all the nessisary programs through, but still nothing. I did stumble across this Text Note in my windows search bar: $Id: megasquirt-ii.ini.ms2extra,v 1.133.6.70 2008/04/26 20:58:42 jsmcortina Exp $ ; configuration defines ;Normally these next lines should be UNset ;This enables the trigger logger page. At this time no simple software exists to interpret the data ; ;For TunerStudio ;the unset is just the default. All settings defined in the ini can be changed through the UI ;On the Menu: ; Project-->Properties ; Click the Settings Tab. #unset TRIGLOG ;This enables the "full" CAN/serial commands so this INI can be used anywhere on the CAN network. #unset CAN_COMMANDS [MegaTune] MTversion = 2.25 ; MegaTune itself; needs to match exec version. #if CAN_COMMANDS versionInfo = "r\x00\x0e\x00\x00\x00\x3c" ; Title bar queryCommand = "r\x00\x0f\x00\x00\x00\x14" ; Verify against signature. #else versionInfo = "S" ; Put this in the title bar. queryCommand = "Q" ; Verify against signature. #endif signature = "MS2Extra Rel 2.0.0 " ; MS-II sends a null at 20th byte. ; 123456789.123456789. That seems to me that it is comunicating with the M.S. (so it seems) I am lost!!!!!!!
Post by denz on Jul 21, 2010 23:36:04 GMT -5
Saqve the driver to your documents, then go to your docs and open when u do on the left it lets u chose to extract all files, Do so then open all three files. I had to do this to mine. It woulkd not auto opoen all three for some reason. Good luck and njice to mete u.
Post by Stinger on Jul 22, 2010 0:01:10 GMT -5
Have you restarted the computer after the USB driver install?
dizzle
Post by dizzle on Jul 22, 2010 5:06:24 GMT -5
Denz, nice to meet you aswell and i will try that aswell. When you say all three, do you meen on the disk scott sent with the squirt or on his web site?
Stinger, i have turned my computer off the on after install. I am so sorry for all the trouble. this thing is giving me a head ache.
Post by Stinger on Jul 22, 2010 11:54:53 GMT -5
I'm running out of ideas because at this point I'm not sure what is set right and what's not. Have you changed the com port number in tunerstudio > communications and just tried a bunch of them (com1, com2, com3, etc.) clicking the "test port" after each selection?
dizzle
Post by dizzle on Jul 22, 2010 18:19:13 GMT -5
In tunner studios, i have tryed all of the ports and tested. It still will not let me veiw what port i am operating out of in windows though. Keeps telling me driver not installed error (28).
dizzle
Post by dizzle on Jul 22, 2010 20:02:45 GMT -5
I have been all over the net and finding that this error code 28 is becoming a big problem with windows 7. The only type of fixes that i am coming up with are to down load some type of system scan progam that will detect and fix the problem. I want to try them out but dont know were i can find a safe one. Any suggestions?
Post by Stinger on Jul 22, 2010 23:09:21 GMT -5
Odds are the suggested programs are safe. If you question their safety, do a google search for the specific program you are looking at with "x program scam" or "x program safe", etc.
