Post by oneowner88lx on Sept 23, 2011 21:53:04 GMT -5
This is on a 90 degree rotated upper set up on an '88 LX with AC. Everything worked out real well except where the cold side pipe interferes with the lower radiator hose. Any ideas how to make this fit a little better?
Post by oneowner88lx on Sept 23, 2011 21:53:36 GMT -5
From another angle
Post by oneowner88lx on Sept 23, 2011 22:01:57 GMT -5
The intake was rotated by Murkur Depot and shortened by about 1".
Post by oneowner88lx on Sept 23, 2011 22:04:56 GMT -5
Another
Post by oneowner88lx on Sept 23, 2011 22:10:27 GMT -5
Front view.
ccm302
86 SVO
Post by ccm302 on Sept 24, 2011 9:43:32 GMT -5
Can you go above the radiator pipe? I had to cut some plastic out to make mine fit. Then I was able to twist the pipe coming off the intercooler up and go above the radiator hose. Not sure if that makes any sense. Mine is also stock location piping.
ccm302
86 SVO
Post by ccm302 on Sept 24, 2011 9:45:02 GMT -5
After a second look, it looks like your frame is in the way of that. Hard to tell.
Post by oneowner88lx on Sept 24, 2011 10:01:26 GMT -5
That is something we need to look into cause from the picture it looks like the U bent pipe coming from the intercooler can be twisted up closer to the frame. If we do that then the pipe up by the throttle body will need to be shortened some. Hopefully we wouldn't have hood clearance problems with it sitting higher. Might have to shorten the radiator hose so it sits closer to radiator.
Post by oneowner88lx on Sept 24, 2011 10:02:47 GMT -5
After a second look, it looks like your frame is in the way of that. Hard to tell. Click on the second picture to enlarge and it looks like there is a lot of room for that pipe to come up.
Post by Stinger on Sept 24, 2011 23:40:55 GMT -5
Typically the rotated intakes point at a downward angle (from Bob or Bo) which pushes everything down a couple inches. In this case, I'd look at going above the hose. If that doesn't work, I'd look into shortening the section that attaches to the radiator so the bend is right next to the rad.
Post by oneowner88lx on Sept 25, 2011 8:03:45 GMT -5
Not enough room for hose to go under the pipe even if the hose is cut. That pipe has to be moved up some how.
Post by Stinger on Sept 25, 2011 21:56:30 GMT -5
What about shortening the hose going into the radiator?
If need be, I can send another coupler and 2 clamps so you can cut the vertical section to shorten or lengthen it as needed.
Post by oneowner88lx on Sept 27, 2011 19:19:17 GMT -5
Thanks for offer, we will let you know, we need to go out and mess with it a little and see what we can do. Love the quality of the kit, just need to get this one little issue worked out.
Post by oneowner88lx on Sept 29, 2011 19:29:43 GMT -5
We have a solution. We added a section of pipe on the lower u bend off the intercooler to move everything back. Then we trimmed the pipe up by the throttle body. Compare this to the picture above and the pipe angle and placement has a much nicer look.
Post by oneowner88lx on Sept 29, 2011 19:31:01 GMT -5
Under the car. Its ugly but its under the car and does not leak.
