Post by dsrace on Aug 21, 2018 16:00:07 GMT -5
why not the ls1 coil?
Post by th3cavalry on Aug 21, 2018 16:12:30 GMT -5
The LS1 coils have a much lower milliamp rating than the LS2 coils.
Post by Stinger on Aug 21, 2018 19:21:48 GMT -5
And they use a different connector. No reason to make a special harness for an inferior coil when there are better options for the same price. As stated, the LS2 and later stuff has nearly 3x the amperage.
Post by thefoxmulder on Aug 22, 2018 9:30:57 GMT -5
Cool. Simple enough. So we would be replacing the guts of the distributor with a pickup? Or is it Crank trigger based? I know 64bit came out with their bolt on crank trigger wheel kit. I imagine the harness is plug n play as well?
Post by Stinger on Aug 22, 2018 10:49:07 GMT -5
You can run our CAS which replaces the distributor parts with 24-1 components, or you can run a crank trigger and cam sync. The harness plugs into the expansion port and runs to the stock LS coil harness(es). You connect it to the CAS or crank/cam stuff of your choice.
Post by th3cavalry on Aug 22, 2018 10:52:34 GMT -5
You can run our CAS which replaces the distributor parts with 24-1 components, or you can run a crank trigger and cam sync. The harness plugs into the expansion port and runs to the stock LS coil harness(es). You connect it to the CAS or crank/cam stuff of your choice. Have any word on pricing?
Post by Stinger on Aug 22, 2018 11:58:29 GMT -5
CAS kit is $275. Still finalizing harness pricing but it will be similar to CAS pricing.
Post by dsrace on Aug 24, 2018 8:04:02 GMT -5
that will make for a clean easy set up for sure.
Post by Stinger on Sept 4, 2018 14:52:48 GMT -5
The machinist who was making the CAS parts was involved in a bad motorcycle accident over the weekend so the parts will be delayed for a while, not sure how long until he's able to communicate with us.
Post by thefoxmulder on Sept 6, 2018 9:42:11 GMT -5
The machinist who was making the CAS parts was involved in a bad motorcycle accident over the weekend so the parts will be delayed for a while, not sure how long until he's able to communicate with us. Man that's awful. Sorry to hear that. Hopefully he's okay. Did you come up with a harness pricing? Would love to see it/get an idea of what I may or may not be doing with this thing.
Post by Stinger on Sept 6, 2018 10:04:39 GMT -5
Harness will be $275 or a little less.
Post by thefoxmulder on Sept 28, 2018 6:44:29 GMT -5
How's the Machinist doing? Hopefully he's recovering well.
Curious if the ETA is more solid now. Trying to determine my winter projects lol
Post by Stinger on Sept 28, 2018 9:57:25 GMT -5
He's not back to work yet.
Post by boostedsbf on Oct 8, 2018 18:35:04 GMT -5
+1 for this kit really hope ur machine guy is alright and can get the parts out
Post by infidelracing on Oct 10, 2018 16:54:54 GMT -5
Any word yet
