Post by Stinger on Jan 9, 2011 14:14:31 GMT -5
Depends on how much blowby you have. Mine went 1000 miles and had about 1.5" of oil in the tank. It comes with a valve you can twist to drain it. You can actually put a fitting on the bottom and hook a hose to it and run it to the turbo oil return fitting. As long as this hose is small, you can leave it open and it will auto-drain whenever you're not under boost.
tonye
Post by tonye on Jan 9, 2011 14:21:06 GMT -5
thanks, good to know
Post by forced86 on Feb 24, 2011 0:00:19 GMT -5
hey Stinger,
i have a question about the crankcase vent itself. does it have any o-ring or rubber gromit where it goes into the block? do they go bad? its loose and i wasnt sure if there was some kinda seal there or if thats normal. i getting ready to install head and intakes and would like to address it before hand.
thanks Cody
Post by Stinger on Feb 24, 2011 1:44:58 GMT -5
It's a press fit into the block.
Post by Detroitthunder87 on Mar 15, 2011 22:20:23 GMT -5
Hey Stinger! Is it normal for smoke to come out the breather at the top of the moroso catch can? Thanks
Post by Stinger on Mar 16, 2011 14:11:14 GMT -5
No but steam will come out normally.
Post by Detroitthunder87 on Mar 16, 2011 15:06:53 GMT -5
lol ohhhh ok! thought it was smoke. ;D
Post by Stinger on Mar 16, 2011 18:16:58 GMT -5
It may be but it shouldn't be. Mine is steam.
Post by jhcb360 on Jun 3, 2011 10:15:11 GMT -5
How goes it? Been having blow by issues. Vented the valve cover, O ringed dipstick tube and rtv'd the snot out of it. Still yet having oil blow out and its raking at my nerves. came across this system of yours and i had my father in law check it out. He mentioned that i would have moisture issues in the valve cover in the winter. Pretty much curious as to whether anyone has had an issue with this in regards to this setup
Post by Stinger on Jun 5, 2011 18:41:51 GMT -5
If you're referring to moisture if it's just sitting, I suppose any open system could have some condensation (though engines condensate with a closed system as well). It will burn off quickly when the engine comes up to temp.
Post by miles84 on Aug 15, 2011 11:22:09 GMT -5
Stinger have you or anyone ever tried the crankcase evacuation system that ties into the exhaust? We put it on our mini stock and it eliminated all blow-by and leaks. Just wondering if it would work on a turbo setup.
Post by Stinger on Aug 15, 2011 14:42:56 GMT -5
I haven't tried it but I've seen some people do it. It's critical to have a restriction free exhaust for it to work and this is more difficult (but not impossible) on a turbo car.
svslow
![*](//storage.proboards.com/forum/images/stars/star.png) ![*](//storage.proboards.com/forum/images/stars/star.png)
Post by svslow on Sept 26, 2011 13:58:12 GMT -5
I used this set up for my system but I used a -12 AN line out of the the block with no PCV and then a -8 off the valve cover to my catch can, works great.
Post by cjdavid on Oct 12, 2011 18:44:16 GMT -5
Would there be an issue to mount the catch can at a lower location or would that make it suck the oil out of the crankcase?
Post by Stinger on Oct 12, 2011 23:40:39 GMT -5
How much lower than the factory crankcase breather do you think you can go?
