Post by bobbarker on Jul 3, 2009 23:18:51 GMT -5
How streetable is this car? Compared to daily driving duties?
Post by Stinger on Jul 4, 2009 9:41:01 GMT -5
It's completely streetable. Drives as good or better than a stocker out of boost. It certainly makes more power out of boost than a stock 2.3T does.
Post by bobbarker on Jul 6, 2009 19:36:05 GMT -5
I hope you don't mind but I'm going to try and mirror my car to what you've done here. It's a daily driver though, not just a weekend warrior, I drive 20 miles to work one way... so hopefully it's as tame as it sounds. Even with that stage 3 cam it doesn't loose power at idle? Thanks again for all this info!
Post by Stinger on Jul 6, 2009 22:20:56 GMT -5
The airflow mods offset the loss of power by the cam at "idle". If you are concerned with mileage, a stage 2 or 1.9 cam may be better for you.
Post by bobbarker on Jul 7, 2009 8:32:39 GMT -5
Mileage isn't a concern. I was mainly concerned about the car in traffic. Sometimes it gets bad and I have to sit for a little while.
What do you mean by airflow mods? Also in the pics the filter goes straight into the turbo, no VAM or MAF meter to be seen. Am I just missing it or what do you use for measuring air?
Post by Stinger on Jul 7, 2009 12:30:22 GMT -5
Airflow mods are items that increase airflow through the engine (header, 3" exhaust, larger turbo, fully ported intake, K&N filter, ported Aluminum head, etc.).
I'm running a megasquirt ecu which doesn't use an air meter, it is a speed density system.
Post by bobbarker on Jul 7, 2009 16:42:03 GMT -5
The megasquirt ecu's are the one's they call a "project" or something like that right? They are the one's that are like a blank circuit board that you have to build yourself...
Post by Stinger on Jul 7, 2009 17:53:36 GMT -5
Yes, though they are available in assembled form as well for a higher fee.
Post by bobbarker on Jul 7, 2009 18:07:08 GMT -5
From the Megasquirt site? Made specifically for our cars? I didn't see that on their site.
How do you like using the speed density compared to a MAF set up?
If I were to go with a MAF set up, can it be tuned with more modern tech like SCT Xcals or Sniper software? Or would that require a different kind of ECM?
Post by Stinger on Jul 7, 2009 23:33:33 GMT -5
No, from wilsonracingms.com
None of the tuning options are any better than your own abilities to understand the software and the engine's requirements.
No, on the SCT or Sniper, though there is other "modern tech" tuning software/hardware available that is just as or more powerful than those options. This is more of a ECU Tuning Tech subject though.
Post by Stinger on Jul 8, 2009 23:22:00 GMT -5
I'm still dealing with some alternator issues but I did take it out for some test runs tonight. With the old setup (ported iron head with worn valve seats and ranger roller cam and LA3 ecu, everything else the same) it would run 102-103mph at 22-24psi. I did some gtech runs tonight at 8psi with the new setup and ran a best of 101.8mph...I'd say it's got the potential to really haul ass
Post by Stinger on Jul 12, 2009 12:12:49 GMT -5
Here are some new pics... Head back on after headgasket replacement and some other tweaks: Intercooler tubing painted and installed: Side view:
Post by SLO FRD on Jul 16, 2009 13:55:10 GMT -5
Hey is that intake manifold better than the square intakes?
Post by Stinger on Jul 16, 2009 15:45:00 GMT -5
In ported form they are both about the same. The inline lower is better for making custom plenum intakes out of though. I've got a powdercoated square intake that is going on after it is ported.
Post by SLO FRD on Jul 17, 2009 10:56:11 GMT -5
Ok Thnx for the info! I have both and there both ported. But im using the squareintake
