Post by Stinger on Jun 22, 2009 18:11:24 GMT -5
Again, without specific issues (what acronyms?), we can't help you. If you'd looked in the Frequently Asked Questions area of this forum ( which is designed to get individuals who are new to 2.3T's like you up to speed so they know what we are talking about), you would see the FIRST thread in that section is title "Acronyms (What certain terms seen here mean)"...I bet if you read it you'll gain a ton of information Pictures will do you no good, that is why there are none included in the article. All you'll see is wires coming out of the plug, just like they do in stock form.
Post by 93stangnow23t on Jun 22, 2009 18:42:43 GMT -5
well no two plugs are the same ill post up the ones i dont understand i can put a plug together with an acronym as long as i have a pic of it but thanx for the advice ill look in the section.
Post by 93stangnow23t on Jun 22, 2009 18:51:25 GMT -5
ok well i think i figured out the major problem from what i can tell the TFI conector from the Tbird needs to be cut off and and moved to the Mustang you also have to cut off the coil pack plugs (two black ones) and replace them with the one from the TC am i correct in assuming this?
Post by 93stangnow23t on Jun 22, 2009 18:59:10 GMT -5
ok now i finnally understand after rereading a few times but a few quick questions what sould i do about the fuel lines (i have a 86TC motor), what should i do about the egr solenoid wiring, can someone post a pic of the ACT sensor or were they put it is what i mean.
Post by Stinger on Jun 23, 2009 1:46:44 GMT -5
No, you don't use the TFI plug from the TC (all ignition wiring details are covered on the swap page). You do use the coil plug but I don't always advise removing the dual coil wiring.
Looking at the acronyms page, what does ACT sensor stand for (this will help to tell you where it is located as well)?
What year TC engine are you using for the swap?
I'm not trying to be a pain in the ass, I am making sure you are ready to do the swap before you dig into it and screw yourself over by doing irreversible damage.
Post by 93stangnow23t on Jun 23, 2009 12:11:32 GMT -5
ACT=Air Charge Temperature
its an 86
ok and for the plug i realized that the module that sends power to the coils is in ruffly the same spot as the Distributor and the plugs are close to if not the same so im thinking im using that plug to go into the Distributor.
Post by Stinger on Jun 23, 2009 12:15:08 GMT -5
You may want to note what year range of donor TC and or donor TC ecu/air meter the swap pages uses as other years don't work.
Air Charge Temperature sensors are located in the intake manifold, 86 TC's don't have one though.
You are correct on the TFI plug.
Post by 93stangnow23t on Jun 23, 2009 13:14:54 GMT -5
i bought a 88 LA3 and a Large VAM and the 86's came with Brown top injectors.
ok so what should i do about the ACT?
Post by Stinger on Jun 23, 2009 16:59:31 GMT -5
Use the one on your Mustang like outlined in the swap page.
Post by 93stangnow23t on Jun 23, 2009 17:07:58 GMT -5
ok so mines in the intake manifold right.
Post by Strangeleak on Jun 23, 2009 19:22:44 GMT -5
It's like Obi-Wan and Luke....the early years! ;D
The answer to your question is also stated in Stinger's "How-To". For the 91-93 Mustang Wiring Swap.
Quoting from the "How-To" "Note that you will need to move that ACT Sensor that was located in your airbox to somewhere after the intercooler. The 87-88 intakes already have them in the back of the lower intake. You will need to move/lengthen the wires to reach the new location. I chose to mount mine in the IC tubing right before the throttle body."
Post by Stinger on Jun 23, 2009 20:37:33 GMT -5
Exactly, ALL of the info is there...you just have to read it (not just glaze over it).
Post by 93stangnow23t on Jun 23, 2009 21:35:35 GMT -5
oh i did read it its just hard to remember every sentence im only human and i havent done the swap so i dont remember every detail thanx for postingit up tho.
Post by Stinger on Jun 23, 2009 22:36:02 GMT -5
I know you can't remember it all. You should keep reading through it though until you do remember what info is included in the guide (like that it includes ignition wiring, ecu repinning info, act wiring info, etc.).
Post by Strangeleak on Jun 24, 2009 8:22:33 GMT -5
Just an idea, print out everything on that page, and anything you find helpful for your swap, for that matter. Create a book and read it often. Familiarize yourself with everything. I am only in the planning/engine rebuild stage of my swap and I have read the "How-To" at least 15 times.
Also I suggest you read through all the post in the tech forum. Regardless if you need to or not. You can learn alot about your vehicle, the way it operates inside and out, and if a problem surfaces with your vehicle, you may be able to diagnose the problem quickly.
