Post by Stinger on Sept 20, 2009 16:45:07 GMT -5
A pic of what?
Post by 93stangnow23t on Sept 20, 2009 16:55:05 GMT -5
The oil feed line that you think is leaking into the turbo or if you could give me a good description of were it is located at.
Post by Stinger on Sept 20, 2009 22:39:41 GMT -5
Not an oil feed line...valve cover vent tube, comes off of valve cover breather and goes to the inlet of the turbo.
Post by 93stangnow23t on Sept 20, 2009 23:06:43 GMT -5
Ah thats probably it most likely the PCV valve is bad.
Post by 93stangnow23t on Sept 21, 2009 15:23:55 GMT -5
how can you check to see if it is bad just if there is oil in it?
Post by Stinger on Sept 21, 2009 18:10:05 GMT -5
You shouldn't be able to blow ANY air through it in one direction.
Post by oneowner88lx on Sept 21, 2009 18:25:01 GMT -5
On turbo cars if boost blows past the PCV valve it then goes into the crank case, up to the valve cover, and then out the vent tube which in our case is hooked to the turbo air inlet. In a lot of cases PCV valves don't completely stop the boost from getting by causing oil blow out issues. What you want is the PCV to be able to suck in air at low engine speeds then under boost close up. That is why most people add a check valve between the intake and PCV or just replace the PCV with a check valve.
Post by 93stangnow23t on Sept 24, 2009 21:18:35 GMT -5
PCV was defiantly bad didn't restrict flow at all were can i get a check valve or a new PVC?
Post by Stinger on Sept 25, 2009 10:32:46 GMT -5
You'll want to only use a Motorcraft brand PCV valve (available from Ford or an online ford factory parts house). Check valve can be found anywhere...parts store, junkyard, that old broke down car in the back yard, etc.
Post by 93stangnow23t on Sept 26, 2009 23:43:45 GMT -5
Is the SVO header any better than the TC header from 86?
Post by Stinger on Sept 27, 2009 2:12:49 GMT -5
Exhaust manifold, not a header. There are two stock manifolds for 2.3's an "E6" and an "E3" casting. These are the last two digits cast into the part number on the manifold. E6=good.
Post by 93stangnow23t on Sept 27, 2009 8:04:41 GMT -5
Thanx sorry about the word mix up.
Post by 93stangnow23t on Sept 27, 2009 16:54:47 GMT -5
Is the EGR supposed to be plugged like this?
Post by Stinger on Sept 27, 2009 20:55:21 GMT -5
No
Post by 93stangnow23t on Sept 27, 2009 21:13:02 GMT -5
That's what i was thinking its plugged on the EGR side and the intake side
Also how do you rotate the turbo (intake side) to put a stock 87-88 TC intercooler on?
