Post by 93stangnow23t on Jun 24, 2009 9:55:58 GMT -5
i did print it out and read it a few times i gave it to my brother to get him up to speed but guess what he hasnt read it and its been 2 weeks.
Post by 93stangnow23t on Jul 3, 2009 0:37:33 GMT -5
Post by 93stangnow23t on Aug 6, 2009 22:40:22 GMT -5
well it looks like im going to be getting my wiring harness done by matt not a sure thing yet but since i have only 10 days to get it done i will be cooking to get it done.
Post by Stinger on Aug 7, 2009 18:01:41 GMT -5
He said something about that...
Post by 93stangnow23t on Aug 9, 2009 13:30:24 GMT -5
i havent been able to get a hold of him for the past few days and im getting a little anxious since i need the car done by the 19th.
Post by Stinger on Aug 9, 2009 18:36:37 GMT -5
I'll ask him...
Post by Stinger on Aug 9, 2009 18:48:57 GMT -5
He's not near a computer...said send it all his way asap, be sure to include name, phone number, email, details for car, etc. so he knows what's going on when it arrives. PM me if you need the address.
Post by 93stangnow23t on Sept 17, 2009 19:29:43 GMT -5
UPDATE: well today i bought a new hydraulic cylinder for my cherry picker since it was bad and it worked really well. Started pulling my turbo off the shaft doesn't wiggle any at all fans aren't damaged but i ran into two problems. One couldn't get the O2 sensor off and Two there are five bolts holding the exhaust elbow with the internal waste gate actuator on it and FOUR yes FOUR of the bolts broke out of the FIVE.
Post by Stinger on Sept 17, 2009 19:49:41 GMT -5
It is pretty common for those bolts to break when not removed properly. Fortunately there is typically no reason to remove them.
Why were you removing the exhaust elbow?
Did you consider stopping after the first broke and considering new ways to remove them or to not remove it at all?
For the 02 sensor, heat is your friend...get it glowing orange and then remove unless you've already destroyed the hex section and can no longer get a good grip on it.
Post by 93stangnow23t on Sept 17, 2009 19:53:59 GMT -5
well im pulling the turbo off wanting to replace the gasket also pulling the exhaust off.
Post by 93stangnow23t on Sept 17, 2009 22:15:09 GMT -5
two quick questions
ONE which intake is better stock turbo one or the 93 turbo one that splits? TWO were can i get a turbo rebuilt and how much? turbo has blow by oil in intake.
Post by Stinger on Sept 18, 2009 21:26:06 GMT -5
There is no gasket behind that elbow...
Exhaust removes with two bolts at the end of the elbow.
No reason to remove the elbow.
You need to decide whether the oil is coming from the turbo or (more likely) from the valve cover vent hose that goes into the inlet elbow of the turbo. Odds are it is the vent hose, not the turbo that is putting oil in the turbo compressor side.
Any turbo shop can rebuild it...probably $300 or so...not worth it.
The intakes aren't interchangeable so it doesn't particularly matter which is better...different bolt patterns at the head. You run the one that bolts to the head.
Post by 93stangnow23t on Sept 18, 2009 23:09:23 GMT -5
well there is oil in the intake and there was oil in the vam as well when i pulled the motor.
Im pulling the turbo to replace the gasket between the turbo and exhaust also doing the manifold gasket.
Post by Stinger on Sept 19, 2009 23:49:49 GMT -5
Oil being in those locations doesn't change what I said above about the source of the oil. It "could" be the turbo but most likely is not.
I still don't know what removing the exhaust elbow has to do with replacing the turbo gaskets but I guess it doesn't matter at this point.
Post by 93stangnow23t on Sept 19, 2009 23:59:30 GMT -5
do you have a pic of it?
