Post by duffy1992 on Apr 4, 2010 18:35:14 GMT -5
Finally got my car running but am not sure what to set boost to. Motor is a 1988 turbo coupe motor, big vam, 36 lb injectors, merkur t3 non intercooled. What can i run the boost at without having a problem right now it is at 10psi.
Post by Stinger on Apr 4, 2010 20:14:13 GMT -5
Depends on a million factors. Non-intercooled severely limits it though. You'll need to listen for detonation and back off if it does (sounds like gravel in a tin can behind the dash or around the transmission). Your max will be somewhere between 12psi and 15psi (probably closer to 12).
Post by duffy1992 on Apr 5, 2010 8:50:34 GMT -5
ok ill just leave it at 10 until i get the money for a front mount i have the top mount but dont no anyway to make it work
Post by oneowner88lx on Apr 5, 2010 20:58:06 GMT -5
Yeah I would leave it at 10 until you get a front mount. That is what we are doing. Better safe then sorry.
Post by duffy1992 on Apr 5, 2010 22:18:09 GMT -5
ya especially with my luck if I go any higher I will blow something. When I first put the motor in the ihi was bad so i found this t3 ran it for two days and it went out so now that its rebuilt trying to take it easy on everything. lol
Post by denz on Apr 6, 2010 21:27:33 GMT -5
for now use top mount as a front mount.
Post by duffy1992 on Apr 6, 2010 21:40:49 GMT -5
Thats what I was thinking but how much boost could I run then? Also been haveing a problem starting it will fire then die if you try it again it will stay running but fluxuates from 1200 to 600 then eventually goes to about 1100. It didnt do this the first time I had the t3. I ran codes and the only codes are 81, 82, and 84.
Post by Stinger on Apr 6, 2010 21:54:15 GMT -5
Sounds like you need to clean the IAC and set the base idle as detailed on our main site.
I wouldn't waste any money front mounting the stock intercooler (couplers, tubing, clamps, etc. will be well over $100).
Post by duffy1992 on Apr 6, 2010 22:03:57 GMT -5
I cleaned the idle air tonight and it was still doing the same thing I will set the base idle tomorrow. Is it posible that maybe a vacuum leak could do this I will check for leaks tomorrow too.
RoLo
Boosting 15 psi
Post by RoLo on Apr 6, 2010 23:40:38 GMT -5
go for it get some carb cleaner and spray that sucker to find any leaks sure did help with me. also let the iac sit over night with the carb cleaner in it might be more dirtier than you think. As for the top mount why don't you just hook it up to the tb and turbo, like the svo's and t-birds.
Post by oneowner88lx on Apr 7, 2010 11:39:51 GMT -5
As far as the idle goes I would do a boost leak check to make sure you don't have vacuum leaks.
Also, make sure the TPS voltage is correct and consistent at idle. Hook up volt meter, move throttle to full open, check voltage, go back to idle check voltage, and repeat a dozen times or so to make sure the voltage is consistent. Also look for flat spots during the sweep.
Post by duffy1992 on Apr 7, 2010 16:07:11 GMT -5
The top mount wont clamp to this compressor housing because it has the two bolt flange. I got the base idle set havent started it yet. Couldnt find any vacuum leaks so im not sure what it is after it is warm the car runs and idles pretty good.
Post by duffy1992 on Apr 7, 2010 19:29:47 GMT -5
After setting the base idle and letting it set I started it and it doesnt die now the rpms still fluxuate a little but it does run and idle now. Thanks guys next is to get and intercooler for it.
Post by duffy1992 on Apr 8, 2010 18:47:47 GMT -5
What does it mean if there is a white milky substance on the bottom of the pcv valve and the valve cover vent? I thought maybe it was the head gasket but oil is clean and all 4 cylinders have good compression?
Post by Stinger on Apr 9, 2010 0:25:23 GMT -5
It could be condensation in the oil, it could be milky oil from a previously blown headgasket. I'd wipe it off and see if it returns.
