Post by duffy1992 on Apr 16, 2010 19:20:58 GMT -5
It must have just been condensation because it never did come back. Does anyone know where i can get a new piece to go from my outlet tube on the turbo to the throttle body? The orginal one has some cracks and is starting to fall apart and im pretty sure it is leaking.
Post by Stinger on Apr 16, 2010 23:42:00 GMT -5
Not sure if Ford or a parts store has a listing for one. I'm pretty sure one or the other does though.
Post by duffy1992 on May 1, 2010 15:47:08 GMT -5
car seems to be running a little rich would it be because i have the o2 ground hooked on the side of head like factory?
Post by Stinger on May 1, 2010 17:39:55 GMT -5
What is "a little rich"? The factory never grounded anything to the head.
Post by duffy1992 on May 1, 2010 17:53:03 GMT -5
The ground that hooks to my lower intake as far as rich my oil seems to have some gas in it and doesn't get very good mileage prbly close to 15mpg
Post by Stinger on May 3, 2010 22:58:04 GMT -5
Oh, that's the injector harness ground. You can make a quick jumper wire to ground to the turbo to see if it's the problem.
Post by duffy1992 on May 4, 2010 0:06:04 GMT -5
Ok ill try that tomorrow should I just t into the wire goin to the computer and run it to the compressor housing?
Post by Stinger on May 4, 2010 2:09:06 GMT -5
Yes, just ground the wire at the intake to the turbo hot side.
Post by duffy1992 on May 4, 2010 21:30:59 GMT -5
Well I got the wire on I'm gunna change oil tomorrow and drive it for awhile to see what happens
Post by Strangeleak on May 17, 2010 8:18:04 GMT -5
It's well passed tomorrow, lol! Any luck?
Post by duffy1992 on May 17, 2010 15:53:28 GMT -5
seems to be doing better fuel mileage will get better after I get the stuff for the five speed swap as of right now the a4ld only has 1-3 gear
Post by duffy1992 on Jun 17, 2010 22:59:54 GMT -5
Car idles rought when its around 1000 rpm like it has a miss or something then it will smooth itself out but idles at 1800? It will keep doing this til it eventually dies, I have tried setting base idle, reset time because it was off a bit, switched iac, and now am out of options what could it be?
Any help is appreciated thanks
Post by Stinger on Jun 17, 2010 23:13:26 GMT -5
Have you unplugged the IAC to see if it quits doing that?
Post by duffy1992 on Jun 18, 2010 0:17:39 GMT -5
It don't idle as high but still idles kind of rough, codes are good 81 82 and 84 not sure what it is.
Post by Stinger on Jun 18, 2010 0:27:39 GMT -5
How high is "don't idle as high"? Sounds like a vacuum leak.
