Post by duffy1992 on Jun 19, 2010 22:10:32 GMT -5
Got the problem fixed the one spot in the back of the vac tree came unplugged, now I have another problem trying to swap to five speed but I can't get my speedo cable to reach after I swapped holes
Post by musclelogic on Jun 19, 2010 23:28:30 GMT -5
Use the speedometer cable from a 5 speed car.
Post by Stinger on Jun 20, 2010 0:05:26 GMT -5
Hmm...it should reach. You may just need to remove one of the speedo cable brackets to get a big more slack.
Post by duffy1992 on Jun 20, 2010 22:44:24 GMT -5
I took the bracket off and it reached so its good to go, tranny goes in tomorrow Thanks for you guys help
Post by duffy1992 on Jun 27, 2010 19:31:49 GMT -5
Ok got the tranny in and its runnin great however my speedo is off and not sure why with the speedo at 75 road speed is 65
Post by Stinger on Jun 27, 2010 23:06:10 GMT -5
Sounds like you used the 5 speed speedo gear, not the auto trans speedo gear like is stated in the article.
Post by duffy1992 on Jun 28, 2010 7:36:07 GMT -5
I used the gear from the auto tranny all I did was cut the end so it will fit
Post by Stinger on Jun 28, 2010 12:26:43 GMT -5
Weird, what's your rear gear ratio and what's the numbers on the ID tag on the trans?
Post by duffy1992 on Jun 28, 2010 17:54:06 GMT -5
3.73s and I'm not sure about tranny tag ill have to check I think it has a yellow gear if that helps
Post by duffy1992 on Jul 10, 2010 17:22:41 GMT -5
I was wondering if it is possible to use a greddy type r bov with a vam? I searched it but couldn't find much.
Post by Stinger on Jul 10, 2010 19:03:43 GMT -5
I don't think a Greddy is a dual piston valve for metered air cars so no, not without some "issues".
Post by duffy1992 on Jul 16, 2010 0:14:22 GMT -5
What is the best synthetic oil to run in these motors preferably brand and weight, car is in need of oil change and I would like to go synthetic.
Post by Stinger on Jul 16, 2010 1:04:11 GMT -5
10w30 Valvoline
Post by duffy1992 on Aug 24, 2010 16:34:32 GMT -5
hey guys finally got the fmic and bov on but when I drove it down the road it wants to die when i let off, Im not sure why it is doing this. I did take the vapor box off plugged the port on intake and just left the gas take one open so it could vent. Any help is great thanks.
Post by Stinger on Aug 24, 2010 17:48:27 GMT -5
You most likely need to reset your base idle. Your IAC isn't responding fast enough to "catch" the rpm before it gets too low to stay running. Raise the base idle speed a bit and cleaning the IAC, then resetting the TPS idle voltage should do the trick.
