Post by duffy1992 on Aug 25, 2010 21:48:45 GMT -5
I know this is a stupid question but after I set base idle which im going to put around 1k. Do I just take my multi meter and set tps voltage again to reset it? Thanks for the help
Post by Stinger on Aug 26, 2010 0:24:23 GMT -5
Yes, just measure the voltage and move the TPS until it reads .9-1v.
Post by duffy1992 on Sept 6, 2010 23:03:07 GMT -5
Havent posted for awhile got the front mount hooked up, got it so it wouldn't die, then the n/a clutch decided not to hold anymore so upgraded to turbo coupe setup. It all holds but in first gear Im not feeling boost till 4500 rpms. Thought it was intercooler so tightned everything but still does it, what could it be?
Post by Stinger on Sept 7, 2010 3:16:55 GMT -5
Probably the wastegate flapper being held open. Pull the actuator rod off the flapper arm and see if you can close the flapper farther than the arm allows.
