Post by 93lxturbo on Sept 18, 2010 11:42:11 GMT -5
hows it coming along i dont thank i want to order a la3 and vam again and i have no way of running the car right now, so im thinking of just ordering your kit
Post by Stinger on Sept 18, 2010 17:23:51 GMT -5
Still out a month or better.
Post by 75pinto on Sept 18, 2010 21:33:26 GMT -5
well, i guess i am another squirt head on your waiting list.
Post by bobbarker on Sept 20, 2010 8:50:45 GMT -5
Looking at November already? Dang! At least you aren't rushing things and hopefully it will come out perfect in the first swing, instead of needing to be changed after design flaws are found in real world use. Lots of companies rush things out the door to find they don't fit or work when a shade tree mechanic installs them.
Post by Stinger on Sept 20, 2010 11:59:49 GMT -5
That's the idea...hopefully it's a flawless release.
Post by bobbarker on Sept 21, 2010 7:59:20 GMT -5
So when I get this new ECU going right and I want to do something like a ported head/cam and larger injectors, all I need to do to the MS is tell it the new sizes of the injectors? Is it going to be that simple for every upgrade? Like a larger turbo, just tell it the size and it adjusts from there?
Post by Stinger on Sept 21, 2010 15:02:27 GMT -5
For injector upgrades yes, you just plug in the new value and it adjusts accordingly. For the additional airflow from the head/cam, you'll need to run VE Live (autotune) while you drive around for a half hour or so and let it adjust the VE table to match the new setup.
Post by bobbarker on Sept 21, 2010 15:10:26 GMT -5
Will I have to have a lap top in the car while I'm driving around to do that or can I turn it on, unplug the lap top and take off?
Post by Stinger on Sept 21, 2010 15:57:51 GMT -5
You'll need a laptop in the car to record the datalogging and/or run ve-live.
Post by bobbarker on Sept 21, 2010 16:05:06 GMT -5
good to know. I've got an old cheapie that I was gonna throw in the trash soon, but it might have a reason for life now! How big are the programs and what size/speed processor is needed to run it?
Post by Stinger on Sept 21, 2010 22:37:44 GMT -5
The programs are small and you don't need much processing power. A Win95 laptop would do the job. The main requirement is that the battery will last an hour or so, or you have an inverter to plug it into the car to keep it charged up.
Post by alexs93lx on Sept 29, 2010 10:23:53 GMT -5
Stinger,
Can you please briefly elaborate on using this setup in a 5.0 to 2.3t converted car? I would like to understand how/what I would need wire my 93 (currently a 302 car with stock V8 harness) to use this setup after I finish building my 2.3t. Brief will suffice for now of course.
I want to do this right the first time, so I am going to build slowly and not skimp on the details.
Thanks and looking forward to reading on the site more often!
Alex
Post by Stinger on Sept 29, 2010 11:02:08 GMT -5
Your best bet would be to just use a stock 2.3 harness for your year of car and you're done. Otherwise you can change the 5.0 harness to appear to be a 2.3 harness but skip the air meter wiring as it's no longer needed.
Post by alexs93lx on Sept 29, 2010 11:12:49 GMT -5
That's great. Thank you for the help!
Post by Stinger on Oct 3, 2010 10:18:34 GMT -5
