madmax
Boosting 15 psi
Post by madmax on Nov 4, 2010 19:41:56 GMT -5
What will the new Upgraded ECU be able to handle as far as boost pressure, fuel injector size it will best work with (largest size it can handle?)? Will the engine function as well as it would with a stock as far as cold cranking, idiling. What type of O2 sensor will it accept? I have a one wire o2 sensor and would like to upgrade to a 3 or 4 wire if possible. Any info would be useful. I might have to invest in the Mega Squirt plug and play system if i cant figure mine out.
I have the 2.3 ford turbo on my Sandrail that i made street legal. The engine and current ecu is from a 1986 ford T-bird.......any info would b helpfull thankx, Max
Post by Stinger on Nov 4, 2010 22:58:21 GMT -5
It can read/handle up to 44psi, injector size is basically infinite. It can function better than stock in all aspects if it is tuned well enough. It can also run like an absolute dog if not tuned (just like anything). It will accept any narrow band sensor or wideband sensor (when configured properly with the software).
Post by Stinger on Nov 4, 2010 23:04:13 GMT -5
I dont want to rain on anyones parade here, as I am very familiar with the standalone market and MS for certain, can t count all the cars I have had my hands in... Huber Mustang for one, several cars of mention that have participated and won Hot Rod mag Drag Week. Dont let the fact that this is a PnP piece fool any of you into thinking that you install, start and then go and hammer on the car. base tunes are close to get you going, but all engines are a little different, and one tune doesnt fit all cars... cold starts, accel enrichments, and a dozen other things that will either make starting and driving the car fun or a pain in the rear will need a little tweaking. Read the install guides, read the tuning guides and dont mess with what you dont understand... just my 2 cents You're not raining on anyone's parade. That's been known since the first page of this thread. Plug and Play refers to the ability to plug it into the stock harness and have a base tune to start the car. Then the "play" part begins where you tune the car so it can be hammered on safely. We've also covered the "don't mess with what you don't understand" in this thread. People asked if it's possible to "lock them out" of advanced settings so they don't screw up things by messing with stuff they should leave alone. I'm not sure if you didn't read the thread before posting or just skimmed it, etc. but it's all covered here. Nothing new was mentioned in your thread (except the Hubers winning drag week )
Post by bobbarker on Nov 5, 2010 5:29:23 GMT -5
damn, I was hoping to duct tape it to the side of my steering column and go straight to the track and bust out some 10's... nuts, now I gotta do work to this thing? I quit!
Post by Stinger on Nov 5, 2010 11:38:04 GMT -5
84svo
Boosting 10 psi
Post by 84svo on Nov 8, 2010 21:07:56 GMT -5
stinger will you be offering a t5 and auto ms2 setup?
Post by wired4speed on Nov 8, 2010 21:21:16 GMT -5
I dont want to rain on anyones parade here, as I am very familiar with the standalone market and MS for certain, can t count all the cars I have had my hands in... Huber Mustang for one, several cars of mention that have participated and won Hot Rod mag Drag Week. Dont let the fact that this is a PnP piece fool any of you into thinking that you install, start and then go and hammer on the car. base tunes are close to get you going, but all engines are a little different, and one tune doesnt fit all cars... cold starts, accel enrichments, and a dozen other things that will either make starting and driving the car fun or a pain in the rear will need a little tweaking. Read the install guides, read the tuning guides and dont mess with what you dont understand... just my 2 cents so who is assuming this??? apparently not you... sorry if you took offense... this is probably going to be a great product for the 2.3 crowd. I have just seen many folk break stuff because they are either impatient, uninformed or both... Read more: stinger-performance.proboards.com/index.cgi#ixzz14kQVy8KK
Post by vristang on Nov 9, 2010 1:48:12 GMT -5
With stock 2.3 wiring, I take it there isn't SEFI capability? Or can that be added as an extra?
Post by wesk on Nov 9, 2010 9:26:05 GMT -5
With stock 2.3 wiring, I take it there isn't SEFI capability? Or can that be added as an extra? Correct. It can be supported, and "native" support for 4 cylinder SEFI was left on the board. It obviously will require some level of end user wiring, and a different (than any stock 2.3) engine position input. The "easiest" way to support this has not yet been nailed down.
Post by Stinger on Nov 9, 2010 12:52:23 GMT -5
stinger will you be offering a t5 and auto ms2 setup? The A4LD setup will lose nitrous control in order to control the 3/4 shift and TC lockup control. There will be no required changes to run a T5 or a C4.
Post by Stinger on Nov 9, 2010 12:54:15 GMT -5
I have just seen many folk break stuff because they are either impatient, uninformed or both... I can't argue with that!
Post by bobbarker on Nov 9, 2010 12:59:51 GMT -5
So can I buy one yet?
Post by Stinger on Nov 9, 2010 13:50:50 GMT -5
No...you can look at the pictures I post about a week from now though
84svo
Boosting 10 psi
Post by 84svo on Nov 9, 2010 22:58:13 GMT -5
stinger will you be offering a t5 and auto ms2 setup? The A4LD setup will lose nitrous control in order to control the 3/4 shift and TC lockup control. There will be no required changes to run a T5 or a C4. okay thanks. thats ll i need to know. im going be running a T5 for awhile till i get all the stuff for my c4 setup.
Post by Matt Culpepper 2300gearjammer on Nov 11, 2010 2:13:26 GMT -5
stinger will you be offering a t5 and auto ms2 setup? The A4LD setup will lose nitrous control in order to control the 3/4 shift and TC lockup control. This part is genius as far as I'm concerned.....besides nitrous and A4LD at the same time? I can't think of a way the trans wouldn't break.
