86svo
Boosting 15 psi
Post by 86svo on May 22, 2014 13:50:47 GMT -5
How much is the 90 degree fitting? I ordered the line and fitting for an Hx35 and got the straight fitting.
Post by Stinger on May 22, 2014 14:43:23 GMT -5
The fitting is $10, plus shipping (which is $6 for priority mail or $1 in a regular stamped envelope).
Post by pluto on Jul 20, 2014 7:13:33 GMT -5
I recently purchased a new braided line and "T" adapter. Is this "T" adapter and repositioned oil sender suppose to work with the EGR tube that runs for the exhaust manifold and intake manifold?
Post by Stinger on Jul 20, 2014 23:38:06 GMT -5
Yes.
Post by esteban on Aug 15, 2014 5:14:58 GMT -5
For the stock turbo, stock location feed line, do you sell a 45* fitting?
Post by Stinger on Aug 15, 2014 10:42:44 GMT -5
We have a 45 degree fitting for those running IHI's.
Post by esteban on Aug 15, 2014 21:11:07 GMT -5
Will it fit the stock t3 on my merkur? If so ill take one
Post by Stinger on Aug 15, 2014 23:43:48 GMT -5
Yes, it's the same thread size and such.
Post by esteban on Jan 12, 2015 1:13:56 GMT -5
Can I purchase the 45* and a straight fitting off your website? Also, how much longer are the other oil lines you offer compared to the stock location T3 line. I need one slightly longer if I run a straight fitting.
Post by Stinger on Jan 12, 2015 2:17:10 GMT -5
None of the fittings are listed separate on the site but they can be purchased individually. We can make a line any length you need (or even easier, if you have one of our lines and just need it "X" longer than it is now. It would be best to email us about this to get it all worked out.
Post by h2osvo on Feb 5, 2018 18:37:41 GMT -5
I have a 84 svo and I have purchased the oil lines for it but now have found out that the engine and turbo are from a turbo coupe. Can I purchase just the fitting for the turbo and use the line I have now?
Post by Stinger on Feb 5, 2018 19:27:02 GMT -5
You can for the feed line but not the return line. It's a different length. If you've got the stock return line I'd just run it.
Post by monte90 on Feb 17, 2018 19:26:05 GMT -5
How do you remove the brass fitting to install the drain line?
Post by Stinger on Feb 18, 2018 0:38:41 GMT -5
Just unscrew it from the block.
Post by monte90 on Feb 18, 2018 12:45:50 GMT -5
Just unscrew it from the block. I can’t get it to budge
