Post by Stinger on Feb 18, 2018 14:23:54 GMT -5
Unfortunately I can't help you remove it. You'll have to use a longer tool for more leverage, or get a bigger/stronger person to try it, or use heat to help free it.
Post by apagnozzi20 on May 12, 2018 12:14:45 GMT -5
Just a quick question, so on the stock Merkur Garrett turbo the oil feed line has a thread pitch of M10x1.0, I have bought a new turbo that has an oil feed thread pitch of 7/16x24, does the "Stock Location or Stinger Center Mount: T3 or T3/T4 Hybrid" oil feed line have both of the 90° adapters or is the 7/16x24 90° adapter separate? Thanks!
~Anthony
Post by Stinger on May 12, 2018 12:21:20 GMT -5
The line replaces all the stock fittings. It threads directly into the turbo with NPT/pipe thread.
Post by apagnozzi20 on May 12, 2018 13:28:26 GMT -5
Well that's what I was wondering, because now it is no longer the stock threads for the feed line, it is 7/16x24 thread pitch for my new turbo oil feed.
Post by Stinger on May 12, 2018 13:38:29 GMT -5
What turbo is this?
Post by apagnozzi20 on May 12, 2018 13:59:54 GMT -5
It is a Garrett GT28
Post by Stinger on May 12, 2018 14:14:17 GMT -5
You'll have to buy the fitting for that turbo to -4AN then. If you can't find a 90 deg fitting then when you order the line get the flipped manifold version so it's long enough to use a straight fitting.
Post by apagnozzi20 on May 12, 2018 16:00:22 GMT -5
Post by Stinger on May 12, 2018 18:34:39 GMT -5
Yes
Post by apagnozzi20 on May 12, 2018 19:35:25 GMT -5
Awesome, thanks for the help!
Post by alpine615 on Oct 11, 2018 21:07:23 GMT -5
Hi Shannon. Is the "Bob Log Flipped" oil return line ($60) version 1 or version 2 (-10 AN)?
Post by Stinger on Oct 11, 2018 22:07:25 GMT -5
All of our returns are -10 AN.
Post by n20capri on May 27, 2019 8:40:41 GMT -5
Stupid question - I need the T3 version right?
Post by Stinger on May 27, 2019 15:07:40 GMT -5
Yes, but it looks like that stock one is doing just fine.
Post by n20capri on May 27, 2019 15:24:07 GMT -5
Nah I spent all day getting it off. Cracked and leaking bad. Nightmare.
Couldn't getting 45 out of the block though so might have to piece something together locally as it doesnt look like yours will fit original 45 coming out of block...
