Post by jnielsen on Oct 24, 2011 9:39:35 GMT -5
I [icked up a deluxe boost valve kit so I can run the min 12 psi, then hit that little red button and switch to 18 just for fun. Question, what psi I should I get the vehicle tuned at? And since the wait on that build, I am getting a 5.0 just so when people see its a 4cyl I can tell them they can race my slower v8 if they want.
Post by Stinger on Oct 24, 2011 11:58:36 GMT -5
You'll want to tune it at the highest boost you can safely run with premium pump gas (which the tuner should be able to figure out if they are worth a damn). It should be somewhere in the 18-22psi range on 93 octane.
Post by jnielsen on Oct 24, 2011 13:34:20 GMT -5
The highest around where I am at is 91 Octane. I figure I should be good up to 18psi. Dont really want to be cranking out much more boost than that.
Post by oneowner88lx on Oct 29, 2011 19:06:42 GMT -5
You will need a SVO or TC flywheel to run the larger clutch in case you don't already have one. Factory 2.3 5 spd Mustangs have the smaller clutch and those flywheels won't work with the larger clutch the SVO and TC use.
Post by jnielsen on Nov 15, 2011 9:20:48 GMT -5
Well it has been decided to actualy get the head and intakes ported. The new HP goal is 350, and eventually hit 400rwhp. I tried to get some pics of the car up and failed at it.
Post by jnielsen on Nov 27, 2011 0:17:54 GMT -5
Top End Kit from Bo with the 1.5 cam and oversized valves should be arriving Tuesday. My wideband has already come in.
Post by jnielsen on Mar 2, 2012 16:25:08 GMT -5
FInally back from Afghanistan. 88 TC engine finally in the shop getting rebuilt, from the bottom up.
Post by Stinger on Mar 3, 2012 13:35:04 GMT -5
Good deal.
Post by jnielsen on Mar 22, 2012 23:02:28 GMT -5
Got some new upper and lower control arms in, also should have and aluminum radiator with some dual fans. My head is done with the valve job for the bigger valves I order. So progress is being made.
Post by jnielsen on Apr 11, 2012 17:22:59 GMT -5
Head is complete. I have a question about what is going to be a good shifting rpm for the track. Stock these thing red line a 6kish. But after mods what would they be able to shift safely at?
Post by Stinger on Apr 11, 2012 17:48:14 GMT -5
Stock shift rpm is actually closer to 5k. With the mods I'd expect it to be quickest shifting around 6k.
Post by jnielsen on Apr 13, 2012 20:49:52 GMT -5
What about safest shifting? Since its going to be my DD it will only hit the track a couple times, however I dont know how many times it will be raced on the street.
Post by Stinger on Apr 13, 2012 23:32:14 GMT -5
The higher the rpm the more stress you put on the engine. Typically a stock 2.3 bottom end (with a head/cam/turbo package that likes to rev) can be shifted at 6500-7000 without issue. Of course that's harder on parts than 6000 which is harder on parts than 5000.
Post by jnielsen on Apr 25, 2012 16:39:42 GMT -5
I found a 84 svo(running), with a 86tc engine LA3. What would be a good price for buying this?
Post by Stinger on Apr 25, 2012 16:45:37 GMT -5
Without knowing any further details, $500-$6000.
