Post by fomoco1969 on Nov 10, 2008 21:13:45 GMT -5
what flywheel do i use with one of your (stinger) sbf trans adapters? do i have to have my sbf flywheel (flexplate) machined? (for AOD auto) please
Post by Stinger on Nov 10, 2008 22:13:25 GMT -5
The offset doesn't change from a sbf to a 2.3 w/adapter. This means you need any sbf zero balance flywheel/flexplate drilled for a 2.3 crank pattern.
We sell an SFI approved aluminum flywheel to go with the adapter on the site for $335 shipped that is lighter than the stock steel 2.3 flywheel. We do not offer a flexplate but Reactor flywheel will make one for you, as will many other companies. You can also have your stock sbf flexplate redrilled and zero balanced. I'm not sure if I'd trust a redrilled stocker at high rpm though.
Post by chemicalexcuse on Nov 10, 2008 23:13:05 GMT -5
You can also have your stock sbf flexplate redrilled and zero balanced. I'm not sure if I'd trust a redrilled stocker at high rpm though. i agree..some things are not worth cheaping out on..your legs are worth more than the price to do it right the first time
Post by Stinger on Nov 10, 2008 23:20:26 GMT -5
Some people may not value their legs nearly as high as you and I...I agree though.
Post by raysmust on Jan 7, 2009 10:36:23 GMT -5
So if the offset does not change then any small block Ford trans should work. I have a 302 with a well built C-6. I am building a high horsepower 2.3 to put back into the car and would like to retain that C-6.
If I get a Reactor drilled flexplate all I should have left to do is machine the pilot hole in the crank to 302Specs?
Post by Stinger on Jan 8, 2009 0:25:14 GMT -5
So if the offset does not change then any small block Ford trans should work. Exactly, that's the point of the adapter. I have no experience with adapting a V8 auto trans to a 2.3 but yes, that sounds correct.
Post by raysmust on Jan 8, 2009 9:45:28 GMT -5
Do you know of anyone that has put a V8 Auto trans behind a 2.3?
Post by Stinger on Jan 8, 2009 14:59:14 GMT -5
These adapter plates haven't been out all that long so I am unaware of anyone that has completed the project at this time. There are at least 4 or 5 that plan to though.
Post by merc460 on Jan 24, 2009 12:14:22 GMT -5
Stinger do you stock the SFI approved aluminum flywheel or is there a waiting period for the flywheel to be made?
Post by Stinger on Jan 24, 2009 13:21:53 GMT -5
They are already made, no waiting period.
boris
Post by boris on Jan 28, 2009 16:13:23 GMT -5
a c6 has to much rotating mass for a 5.0 ,unless your towing something ,so to use one behind a 2.3 seems pointless. a good c4 will get more to the ground!! but thats my opinion and you know what they say about that lol
Post by irsmart21 on Apr 24, 2009 19:54:22 GMT -5
I am currently in the middle of doing a 5.0-->2.3T swap in a 92 LX. I got the car for a great price, with a beautiful black interior. Anyway, I am seriously interested in your adapter plate for the 2.3-->5.0 bell housing. I am curious about the flywheel that you sell. Is the SPEC flywheel already drilled properly for the 2.3 application or is this something that you purchase and re-drill yourself? If it is correct from the MFG, are there any other MFG's that provide a flywheel that would work for my swap?
Thanks for any help you can give
-Sam
Post by Stinger on Apr 24, 2009 21:44:59 GMT -5
It is already drilled properly, just bolt it on. Nobody else makes one.
boris
Post by boris on Nov 16, 2010 0:26:03 GMT -5
hey got your flywheel and adapter for my 2.3 to 5.0 bell i alls am running a dun up 5.0 t5 do you know what pilot bearing is to be used ?? as the 5.0 is larger thanks in advance.
Post by Stinger on Nov 16, 2010 1:13:10 GMT -5
You'll need to get an adapter bushing from Rapido Group.
