Rich
Aug 2, 2009 18:18:53 GMT -5
Post by Stinger on Aug 2, 2009 18:18:53 GMT -5
Remanufactured ECU's are fine.
Rich
Aug 2, 2009 22:18:09 GMT -5
Post by nmanville on Aug 2, 2009 22:18:09 GMT -5
I double and triple checked. The wires run to the right spots on the connector and computer so I am guessing the computer put out the wrong signal for some reason.
Rich
Aug 2, 2009 22:57:12 GMT -5
Post by Stinger on Aug 2, 2009 22:57:12 GMT -5
Well, you can always sell one ecu or the other if it's not the issue...
Rich
Aug 2, 2009 23:37:01 GMT -5
Post by nmanville on Aug 2, 2009 23:37:01 GMT -5
That is a good point. Thanks for all your help. I hope to have it running soon. Thanks again for putting up with my stupid questions.
Rich
Aug 3, 2009 0:48:35 GMT -5
Post by Stinger on Aug 3, 2009 0:48:35 GMT -5
I just hope it fixes the problem.
Rich
Aug 3, 2009 12:34:02 GMT -5
Post by nmanville on Aug 3, 2009 12:34:02 GMT -5
I found a reman computer but it is only advertised as an 87-88 thunderbird turbocoupe vin w or t. Do you know whether this would be an LA2 or LA3 computer?
Rich
Aug 3, 2009 17:31:18 GMT -5
Post by Stinger on Aug 3, 2009 17:31:18 GMT -5
Vin T is turbo, doesn't matter what ecu code it is, it will work for what you need.
Rich
Aug 3, 2009 22:15:21 GMT -5
Post by Stinger on Aug 3, 2009 22:15:21 GMT -5
You can verify the ground side of the injector wiring is correct by disconnecting the ecu, unplug the injectors, then check the ohms between the injector ground wire and chassis ground. An ohms value indicates the wire is grounded somewhere it shouldn't be because the ecu (it's normal ground) is removed.
Rich
Aug 4, 2009 0:15:54 GMT -5
Post by nmanville on Aug 4, 2009 0:15:54 GMT -5
Would the pinouts be different or not?
Rich
Aug 4, 2009 0:30:16 GMT -5
Post by Stinger on Aug 4, 2009 0:30:16 GMT -5
All of the 87-88 ECU pinouts are the same. I'd do the above check before plugging in the new ecu though.
Rich
Aug 4, 2009 0:34:27 GMT -5
Post by nmanville on Aug 4, 2009 0:34:27 GMT -5
I will I just wanted to make sure I would not have to change my pins at the computer
Rich
Aug 4, 2009 21:33:14 GMT -5
Post by nmanville on Aug 4, 2009 21:33:14 GMT -5
There is no breaks in the wire. I did the test and the wires are good to the computer. I took the computer apart and there are no signs of damage. Could it still be bad?
Rich
Aug 4, 2009 23:24:11 GMT -5
Post by Stinger on Aug 4, 2009 23:24:11 GMT -5
Could still be bad, yes.
Rich
Aug 5, 2009 0:21:51 GMT -5
Post by nmanville on Aug 5, 2009 0:21:51 GMT -5
Is there a case ground for the computer. I know there is one through the plug I just want to make sure there is not one through the case.
Rich
Aug 5, 2009 11:40:04 GMT -5
Post by Stinger on Aug 5, 2009 11:40:04 GMT -5
There is a bare terminal coming out of the harness that attaches to a screw about 6" below the ECU location.
