Rich
Aug 6, 2009 13:40:03 GMT -5
Post by nmanville on Aug 6, 2009 13:40:03 GMT -5
What is the difference in the pinouts from the LA2 to the LA3? Is it a better computer?
Rich
Aug 6, 2009 19:32:49 GMT -5
Post by Stinger on Aug 6, 2009 19:32:49 GMT -5
All of the 87-88 ECU pinouts are the same. I'd do the above check before plugging in the new ecu though.
Rich
Aug 6, 2009 19:34:07 GMT -5
Post by Stinger on Aug 6, 2009 19:34:07 GMT -5
Furthermore, they are the same ECU except the LA2 can control an auto trans.
Rich
Aug 9, 2009 21:57:26 GMT -5
Post by nmanville on Aug 9, 2009 21:57:26 GMT -5
just reread the wiring swap and found I am missing the 22k resistor. Can I just get one from radio shack or is there something special?
Rich
Aug 9, 2009 23:20:58 GMT -5
Post by Stinger on Aug 9, 2009 23:20:58 GMT -5
The one in the coil wire? It's not overly critical, don't worry about it.
Rich
Aug 12, 2009 19:17:59 GMT -5
Post by nmanville on Aug 12, 2009 19:17:59 GMT -5
The LA3 computer worked. I don't even think the computer is actually an LA2. Do you know of any other way to tell which computer it is? Also I could not start it today because the battery was dead but I had to use the starter from the 93. Is that ok or does the svo have a larger starter? It seams to crank slow.
Rich
Aug 12, 2009 20:29:19 GMT -5
Post by Stinger on Aug 12, 2009 20:29:19 GMT -5
It says on the sticker what ecu it is...big letters that say "LA3".
The 93 starter is better. A dead battery will make it crank slow, as will excessive timing.
Rich
Aug 12, 2009 21:31:31 GMT -5
Post by nmanville on Aug 12, 2009 21:31:31 GMT -5
Sorry for the confusing post. The LA2 computer a bought said LA2 on the sticker but I think it is a fake. I think someone pealed the sticker off of a real LA2 and put it on the computer I bought. Is there any other way to tell?
Rich
Aug 12, 2009 22:13:07 GMT -5
Post by Stinger on Aug 12, 2009 22:13:07 GMT -5
Why do you think that? I'd start first by comparing the cases, they should look the same externally. You can also take the cases apart and look inside, they should appear 99% the same inside as well.
Rich
Aug 12, 2009 22:51:20 GMT -5
Post by nmanville on Aug 12, 2009 22:51:20 GMT -5
I think that because almost all of the outputs were wrong. I took a look and checked all of my inputs. None of them were right
