Post by Stinger on Aug 26, 2009 19:38:48 GMT -5
Your vam wiring is screwed...you've got at least 2 of the wires backwards.
You need to go back to the turbo swap how to, fix the vam wiring so the colors/pin numbers match what they should be.
I'd also suggest you go through the whole swap page very slowly paying attention to each step and make sure it was done correctly the first time. It's clear there were multiple issues the first time and I'd prefer to not have to fix one problem a week until they are all fixed. The swap guide is there to eliminate this list of problems.
Your map sensor question should also be answered by the swap page, it says to do something specifically to deal with the "map pressure and boost" issue you mentioned. I'm going to assume you didn't do that step either.
