4banger
BANNED
Post by 4banger on Dec 22, 2009 1:08:44 GMT -5
Post by Stinger on Dec 22, 2009 4:11:18 GMT -5
1) Scan for codes 2) Check fuel pressure 3) Verify Cam timing (not ignition timing) is correct
After this is done, report back. If you don't know how to do any of these, 1 and 3 has been explained multiple times on this forum and there is a tech article for 3. 2 requires a fuel pressure gauge.
4banger
BANNED
Post by 4banger on Dec 30, 2009 18:57:41 GMT -5
ok i need some help. i still cant find whats wrong with my car at all, i was told to do a scan well i can afford the 70.00 to have them scan it, but i was told there are some ways you can do it with some home parts is this true. can some one please help me. i need my car back i miss it pleaaaaaaaase help me ok cool ya i will try that hey could it be the CPS cam positioning sensor??? i watched a few vids on you tube and there where a few cars that sounded like they have the same problem and it will not rev over 3000 rpm
Post by oneowner88lx on Dec 30, 2009 19:55:53 GMT -5
Make sure the fuel pressure regulator (FPR) is not leaking causing gas to get sucked into the intake manifold. Pull the vacuum hose off the FPR and see if it smells like gas. And like Stinger mentioned above your timing belt may have slipped.
4banger
BANNED
Post by 4banger on Dec 30, 2009 21:10:11 GMT -5
could the (FPR) cause the car to smoke a grey color and smell like gas. it is not burning oil. but its blowing grey smoke that smells like gas
Post by oneowner88lx on Dec 30, 2009 21:27:36 GMT -5
could the (FPR) cause the car to smoke a grey color and smell like gas. it is not burning oil. but its blowing grey smoke that smells like gas If the diaphram is blown raw gas will go right through the vacuum hose and into the intake and cause smoke. Take the vacuum hose off and see if gas is in there.
4banger
BANNED
Post by 4banger on Dec 31, 2009 2:10:07 GMT -5
ok i will tr this in the morning. dose my car have a crank sensor or a cam positioning sensor??? i called napa and they said they no parts like that for my car instock or that even shows up on there computer
Post by Stinger on Dec 31, 2009 2:28:03 GMT -5
No on the sensors.
Grey smoke is coolant aka blown headgasket. Fuel is black, oil is blue smoke. Yours smells like fuel because the engine isn't burning the fuel in the cylinder that is leaking coolant.
4banger
BANNED
Post by 4banger on Dec 31, 2009 4:28:15 GMT -5
ok would a blown head gasket make it run like this???
Post by Stinger on Dec 31, 2009 11:05:29 GMT -5
It could, yes. You need to do a compression test.
4banger
BANNED
Post by 4banger on Dec 31, 2009 12:24:02 GMT -5
ok my uncle is coming up the 8th jan and he said he would bring every thing up to check it, but if i can find every thing befor then i will get it done sooner. its a little cold here in montana plus its snowing so that make it suck for working out in the cold LOL. i pulled my dip stick out and it looks like there might be water in my oil. i am a little scared to start it agian because i dont wont it to blow up. i cheked my radiator and it seems to be fine, it would be nice to find if this is my problem. i would rather do this and mess with wire ect LOL
Post by Stinger on Dec 31, 2009 13:56:45 GMT -5
If the oil is milky, you certainly have a blown headgasket or other problem that requires head removal...might as well get started with removing it.
Post by turbo2300 on Dec 31, 2009 14:38:48 GMT -5
might as well get started with removing it. and have a friend help you lift it off/on lol
Post by Stinger on Dec 31, 2009 15:32:19 GMT -5
Yeah, if you have help, remove the head/intake/exhaust manifold/turbo as one assembly. No need to take it all apart. Just remove the throttle body, valve cover, timing belt, head bolts, downpipe, oil feed, oil return, water lines, unplug a few wires, and lift if off.
4banger
BANNED
Post by 4banger on Dec 31, 2009 17:07:40 GMT -5
hey i did the dip stick thing but i smelled my oil and it smells like gas. what dose this indacate???
