Post by Stinger on Jan 6, 2010 1:01:59 GMT -5
Yes, it's always step one for any diagnosing...make sure it's the right one though, you have an EEC-IV system.
4banger
BANNED
Post by 4banger on Jan 6, 2010 3:11:16 GMT -5
yes it is its for 81-95 ford cars for the eec-iv
Post by oneowner88lx on Jan 6, 2010 12:00:36 GMT -5
4banger
BANNED
Post by 4banger on Jan 7, 2010 12:51:41 GMT -5
see mine i dont got the screen i have to count the flashed (OLD SCHOOL) lol . but hey for 3.00 of of ebay he11 i cant beat that
4banger
BANNED
Post by 4banger on Jan 13, 2010 3:47:47 GMT -5
hey i will be doing the compresion test tomarrow. boy i hope its just a blown head gasket. thats bad but i hope it aint nothing to do with the electrical
Post by Stinger on Jan 13, 2010 12:41:17 GMT -5
Be sure to hold the throttle all the way open when cranking to do the test on each cylinder.
4banger
BANNED
Post by 4banger on Jan 13, 2010 17:10:48 GMT -5
what is my compression supose to be??? i did the one cylender and its 135 i have not made it to the rest LOL but i want to know what its suposed to be?? when i took the spark plug out it was dirty as hell smelled like gas, that was just leting it run for 3 mins.
Post by oneowner88lx on Jan 13, 2010 18:15:43 GMT -5
Make sure cam timing is correct or the compression test will not be accurate.
Post by Stinger on Jan 14, 2010 0:43:59 GMT -5
The number doesn't really matter, it's how close the numbers are to each other. 135 is fine if they are all there (+ or - 5%).
4banger
BANNED
Post by 4banger on Jan 14, 2010 14:52:42 GMT -5
how do i check the timeing??? i did not start the car befor i did this i was told i could do it cold is this ok???
Post by Stinger on Jan 14, 2010 14:59:22 GMT -5
You should do it at operating temp but most likely cold will suffice.
So what are the results?
You check the timing with a timing light.
4banger
BANNED
Post by 4banger on Jan 14, 2010 16:20:42 GMT -5
Post by Stinger on Jan 14, 2010 18:34:45 GMT -5
It ran so the timing is close enough. Just do the test...cold engine is good enough.
4banger
BANNED
Post by 4banger on Jan 14, 2010 19:31:18 GMT -5
hey stinger i did 3 cylinder's so far. it got way to dark out side to mess with the 4rth 4cyl, i did not wont to take chance stripping it, i got no lights where i work LOL, but here is the reading so far... cyl 1 135, cyl 2 about 150, cyl 3 about 145-150, so what can you tell by this so far??? i am going to do the last cylinder in the morning. are you still leaning towards blown head gasket? thanks man
Post by oneowner88lx on Jan 14, 2010 22:23:16 GMT -5
When I said "cam timing" I meant the the timing between the crank and cam not the ignition timing. Ignition timing has nothing to do with it. Put car at top dead center number 1 cylinder and look in plug hole at cam gear. Mark in cam gear should line up with center mark.
By the looks of you results so far I would say "cam timing" is good.
